2009 Electrcal problems-Help Please !
Old Aug 1, 2023 | 04:46 PM
Roco2009's Avatar
Default 2009 Electrcal problems-Help Please !
My Daughters s60 started having electrical issues and I am trying to avoid costly diagnostic bills . The dash cluster started going out intermintanly and no gauges working - so i thought dash cluster was the problem. Now dash cluster has no working gauges , but turn signals work on the outside of the car. The drivers power seat does not work along with power windows and key FOB . Thought maybe the CEM - called XeMODex - telling me that those are Low speed network issues - just more confused than ever . Dealer want $185 an hour to diagnose
Can anyone give me some insight to help locate the problem , any help greatly appreciated
Thanks Will
Old Aug 1, 2023 | 05:00 PM
Roco2009's Avatar
I did pull the outside cover to the CEM and checked the 2 connectors for corrosion , all looked good. Car starts and drives fine besides these issues . Just not sure how dash cluster and the other problems are related
Thanks Will
Old Aug 1, 2023 | 07:40 PM
Brubro's Avatar
Sounds like contact issues based solely on what you said (intermittent, etc). I'd start with cleaning all contacts & pins on connectors & see if it makes a difference. Corrosion wreaks havoc on electrical systems (obviously), check all major grounds too (especially CEM, body grounds, engine, transmission, etc). That's an often neglected remedy for a lot of strange electrical issues.
Old Aug 1, 2023 | 07:42 PM
Brubro's Avatar
Q: All of this happened at the same time? Dash, windows, seats, etc?
NW Sights
2001-2013 model year V70
Dec 10, 2021 06:07 AM
PandaVolvo08
May 13, 2019 03:55 PM
JBxc60
Nov 6, 2017 05:13 AM
Fyneboy
Feb 17, 2017 12:52 PM
pinopinopino
Jul 11, 2008 10:13 AM
