2013 S60 t5 driver door won't latch
Old May 28, 2017 | 06:52 PM
Ryanpatrick's Avatar
Default 2013 S60 t5 driver door won't latch
I have a 2013 S60 t5 with 68000mi. Upon getting out of the drivers side this morning the door wouldn't latch closed. I live in Arizona so cold weather is not an issue. I tried spraying lube up into the latch without any success. I also tried to take off the door panel to see if something just came unattached but there is some kind of additional panel under the door panel in the way that the window seems to be attached to. Please help if anyone has any insight into my problem.
Old Jul 15, 2020 | 03:35 PM
ifischer's Avatar
Any other advice for this situation? I'm in Texas an it's 1000 degrees outside, so my issue is not the cold, as mentioned in the other threads. I have tried the valet key and spraying lubricant into the mechanism - no change. Pushing the driver's side latch with a screwdriver -- it does not latch shut the way the other doors will.
Anything else to attempt before I replace?
Is replacement fairly straightforward?
Old Jul 15, 2020 | 11:16 PM
ES6T's Avatar
Just so you know, there is a recall to replace all four door latches on that car. Call your dealer to schedule it.
andygoldberg
Sep 2, 2019 08:56 PM
Ryanpatrick
May 28, 2017 06:36 PM
Flow313
Nov 26, 2014 08:09 PM
ovloV7098
1998-2000 model year V70
Jun 30, 2012 07:15 PM
klod622
Jan 31, 2010 06:11 PM
