2014 under glove box fuse box "b"
2014 S60
Having a problem with ALARM SYSTEM SERVICE REQUIRED. I have read that the battery in the alarm module may be bad and that it an drain the main battery. I would like to pull the fuse that supplies charging power to the alarm module battery. The manual states that the fuse in question is F16 in FUSE BOX B located under the glove box. I can locate FUSE BOX A under the glove box and I can remove the cover from that box. However I cannot see how to remove the cover from FUSE BOX B. The manual states the following: Fold aside the upholstery covering the fuse boxes.
1. Press the cover's lock and fold it up.
2. The fuses are accessible.
A decal on the inside of the cover shows the
positions of the fuses.
I cannot locate the "cover's lock" on FUSE BOX B. Can anyone provide any insighe as to what the cover lock looks like and how to access it? A picture would be great if anyone has one.
Thanks to anyone who can help.
Found the answer to this question here: https://www.carcarekiosk.com/video/2...terior/replace
The answer is found in video 2. REMOVE COVER
Obviously the manual was wrong concerning the instruction to "Press the cover's lock . . ."
