What kind of screwdrivers?
Old Feb 9, 2021 | 03:38 PM
Dimitri1976's Avatar
Default What kind of screwdrivers?
Hi all. I have a 2012 Volvo s60. I need to change a fuse that is located underneath the glove box. I need to remove 2 screws to get to the fuse box. Does anyone know what size driver I need? Also, are those Torx screw? Any help would be appreciated
Old Feb 9, 2021 | 06:53 PM
ES6T's Avatar
Torx T25
Old Feb 9, 2021 | 09:23 PM
Originally Posted by ES6T
Torx T25
Thanks so much for the info!
Both of the cigarette lighters are out, front and back. Will I need to replace both fuses?
Old Feb 9, 2021 | 10:01 PM
ES6T's Avatar
They are both on the same fuse. Should be fuse 22 in the smaller fuse box under there.
You don't really need to remove the kick panel to access the fuse box.
Old Feb 9, 2021 | 10:05 PM
Torx T25
How else could I get to it? I tried feeling around for it, even pull the carpeting back. Can't find the box. I saw a video on YouTube and the guy said to remove the panel. But if I can do it without removing it that's even better.
Old Feb 9, 2021 | 10:10 PM
ES6T's Avatar
It isn't under the carpet. Its pretty easy to see. Removing the panel isn't a big deal though if you want better access.
Old Feb 9, 2021 | 10:33 PM
I guess I'll have to look harder lol. But thank you for your help.
deevolvo
Mar 13, 2023 05:23 PM
Kalvis jasko
Sep 10, 2020 09:26 AM
HarleyJohn
Nov 30, 2018 05:04 PM
Newport_j
Jan 4, 2014 11:54 PM
Bluevolvos40
Jul 26, 2013 06:33 AM
