access top of charcoal canister
Old Oct 23, 2018 | 01:55 PM
John Roden's Avatar
Default access top of charcoal canister
2002 NA s60, I asked the mechanic to do a smoke test on the evap system and he reported smoke pouring out of area around the top of the canister. How can I get a look at that area, is there access from the trunk or do I need to drop the exhaust?
Old Oct 23, 2018 | 06:18 PM
ES6T's Avatar
You need to drop the exhaust.
Old Oct 24, 2018 | 07:06 AM
John Roden's Avatar
I'd like to just have all the typical wear items on hand when I start the job, it looks like there are two rubber hoses on the one end of the canister and a third one with a bend in it, looking at the diagram. Anything else I should address while I have it all apart? Is it ok to just replace the rivet on the heat shield with nuts and bolts? Do I need to remove the muffler or just drop it?
Old Oct 24, 2018 | 07:13 AM
ES6T's Avatar
It's likely a split in one of the hoses, so replacing them all would be a good idea.
You can use a nut and bolt in place of the rivet.
If you have a lift, you can lower the exhaust enough without actually removing it. If you're doing it on jack stands, it might be harder but I've never done it that way.
edvard
Sep 1, 2019 11:27 PM
ibified
Jul 2, 2013 01:58 PM
eddyxwb
Apr 23, 2010 09:17 AM
Sofar.
Sep 18, 2008 01:59 PM
VolvoDriver
Oct 11, 2006 08:26 PM
