after market pads and rotors
Old Feb 21, 2007 | 05:35 PM
thullz's Avatar
Default after market pads and rotors
Has anyone put in Mintex brake pads and rotors....they are on ebay for a good price....$140 for rear pads and rotors....wonder how good they are?
any other recommendations for aftermarkets?
Old Feb 21, 2007 | 07:53 PM
akirk6884's Avatar
Default RE: after market pads and rotors
Powerslot Rotors and ECB Yellow stuff or Red stuff pads
Old Feb 24, 2007 | 10:47 AM
Fisher's Avatar
I hear Mintex are the maker of the Volvo OEM pads, which as you know are very good. I will be going with the Mintex for my replacement pads.
Old Mar 15, 2007 | 01:55 PM
maduko's Avatar
They used to be made by Dan Block. But they may have changed or started using alternate OEM sources.
IIRC the Mintex pads used to be marketed as PBR which used to Repco. Those are really good brake pads- but I would recommend the "M" not the "D" compound.
Old Jul 6, 2007 | 07:25 PM
sandders08's Avatar
I been using Mintex brake pads for years... It has a silver metallic formulation that gives the brakes a distinctly different feel while eliminating brake squeal and dust... But as for the rotors, I previously installed a powerslot rotors... Because it has an average 20-percent larger surface area and can reduce a vehicle's stopping distance by up to 33 percent. These oversized rotors also increase brake torque for reduced pedal effort and have a greater thermal capacity that extends performance during continuous hard braking. Venting and drilling was a key consideration in the engineering process of the rotors and ensures maximum heat dissipation for reliable, consistent braking. As far as I can remember utilization of CNC-machined 6061-T6 billet aluminum rotor hats diminishes the rotors tendency to cup under extreme prolonged use and reduces the overall weight of the rotor when compared to cast versions... By the way, I would second the recommendation of the M compound for the pads... Good luck!!!
grndslm
Jun 30, 2012 02:44 AM
Jabber
Dec 21, 2010 11:16 PM
Tgrumley
Nov 27, 2010 12:14 AM
andrewgrhogg
Sep 22, 2005 10:23 PM
indagutter
Jan 5, 2005 01:57 PM
