Anerobic Sealant question
Hi James,
Put it on the head only. Be very careful to put the cover on Even Steven so the cover makes contact all at once. Count the turns on each screw so that they squeeze the liquid gasket even. Let the gasket set.. then finish tight all screws. It's inconvenient to let the gasket set but important. That's how "liquid gasket" said to to it.
I am using the draw down tool to install the cover but once I get it all the way down I can start putting some of the screws in in strategic places to add to what I've already got, especially on the 1 and 5 cylinders The tool will be on cylinders 2 and 4. I will put as many as I can in then let it set. Then put the final ones in after I remove the draw down tool.
James
James
91shelby
11-21-2010 09:50 AM
Heath7
11-05-2010 11:16 AM
