Reset engine maintenance message
Old Nov 26, 2017 | 05:17 PM
kwaskow's Avatar
Default Reset engine maintenance message
How can I do this myself?
Old Nov 26, 2017 | 06:19 PM
pyro71's Avatar
insert key,press n hold trip,turn key to position2,warning light will flash and now let go of trip. remove key. Pretty sure that does it
Old Nov 27, 2017 | 08:23 AM
kwaskow's Avatar
I have a smart key - same process?
Old Nov 27, 2017 | 03:40 PM
pyro71's Avatar
Maybe post your car info in your signature like I did so we know whatcha got
Old Nov 28, 2017 | 09:16 AM
kwaskow's Avatar
Oops!
2011 S60 T6
Old Nov 29, 2017 | 06:55 AM
pyro71's Avatar
I found this procedure for 2011 s60
Press the Start/Stop button once quickly (do not press the brake pedal).
2. Press and hold in the TRIP/ODOMETER reset button.
3. Within 2 seconds, press the Start/Stop to got to ignition position II.
4. Hold the TRIP/ODOMETER reset button until the original value has been reset.
5. The information lamp lights when the reset button must be released.
6. Release the reset button with 4 seconds (if not released within 4 seconds the SRI will not be reset). You will hear an audible beep when the reset is successful.
JMorse
Aug 28, 2012 03:04 PM
alrosec
Dec 4, 2010 11:39 AM
Jazzman08
Dec 1, 2008 05:44 AM
Mark Thebarge
Dec 14, 2007 10:18 AM
Mullica1771
Jan 30, 2007 10:32 PM
