Angle Gear Replacement
I have a 2005 S60 2.5T AWD, angle drive/gear is not sending any juice to the rear. Have one on the way, looks like a pretty straight forward job. Any comments or experiences to share?
if the angle gear is broke, you would have a terrible grinding noise. the passenger side CV shaft runs through it. It should spin the driveshaft at all times, and the rear diff would control the AWD function.
The rear diff is more likely your problem, possibly the viscus clutching, or electronic clutching (not sure exactly which it has, they changed in the mid 00s.
I would check the collar from the angel gear to the transmission.. Is the AG weeping fluid? Is there fluid in it?
Genuine Volvo Angle Gear Collar Sleeve Service Kit, 5-Speed Auto - ViVA Performance
carlheat
Oct 25, 2010 10:36 AM
