Axle Shaft
Old Oct 12, 2021 | 10:56 AM
leftcoast's Avatar
Question Axle Shaft
2003 -2.4T- S60 FWD
Volvo dealership tells me I need to have the right side shaft replaced. Looking on line for the part. The range in price is vast, $89 to $700. Where should I buy this axle shaft?
Thanks for your advice.
Old Oct 12, 2021 | 11:36 AM
Dingus's Avatar
Highly recommend GKN (OE) or Genuine Volvo. Aftermarket applications do not meeting the quality standards of those 2. FCPEURO.COM has lifetime warranty on all returnable products (even oil) I use them for almost all of my car parts. You can also call them up with your VIN and they will get you the correct part. I have seen people have issues in the past with axles because they slightly vary between standard and automatic cars and fwd/awd.
Old Oct 12, 2021 | 05:13 PM
You might/will regret installing a cheap axle. Some of the made in china stuff is worse vibration wise than your worn out axle. +1 on only using GKN or Volvo $$$$
GKN is the real oem on some Volvos.
Why does the Volvo dealer think you need a new axle? Torn boot leaking grease? You complain of a vibration/shaking when accelerating sometimes?
A personal story - an 01 I owned had a torn boot, so I replaced right axle twice with a cheap axle - both replacements vibrated badly. Then I put axle boots (greasy, pain in butt) on old original axle and drove for a few more years.
Old Oct 14, 2021 | 10:39 AM
leftcoast's Avatar
Default Axle Shaft
No vibrations, no noise, no shaking and no leaking under the car that I noticed. Took my car in for the air bag recall to the Volvo dealer. They did the "multi-point inspection" and I get this print out, Right side axle shaft plus alignment parts and labor $1,542 plus tax. The tech didn't give me the luxury of looking at the car while on the lift.
Old Oct 14, 2021 | 01:25 PM
If if ain't broke don't fix it. Probably has a torn boot - you/someone qualified (probably not the guy that wanted to sell you a new axle) could put some boots on it. Or keep driving it.
Old Feb 1, 2022 | 02:03 PM
leftcoast's Avatar
Talking Right front axle shaft end of story
Got the job done at a good shop. The axle shaft is a big heavy-duty piece. I saw it come in the box. Googled the manufacturer and they got good reviews. One month ago installed and no problems at all. Didn't even need an alignment afterward.
$200 cash done and score!
Old Feb 1, 2022 | 05:43 PM
Pretorien's Avatar
Typical Volvo - every time my car is in for routine service, I get the "technician recommends" message. At this point, I flat out don't believe them without confirmation from my indie who will, if necessary, attend to the matter for 1/4 or less than Volvo would charge. I wonder if Volvo has any idea of how much damage to their brand the dealers are inflicting case in point - this is my last Volvo.
ngriffin
Feb 7, 2016 09:48 PM
tr_car_nut
Jul 18, 2013 10:43 AM
PacificNWest
Jun 30, 2013 04:35 PM
01_fast_ride
Mar 11, 2013 09:04 PM
