break fluid leak help
Old Jan 21, 2011 | 09:51 AM
volvovera's Avatar
Default break fluid leak help
I noticed a 6" diameter spot on the driveway from a fluid leak in the driver-side wheel well. And when I checked the break fluid reservoir, I found only the area around the cap is wet. The level of the fluid is above the full line.
The front break pads were replaced two weeks ago.
I wonder whether the leak is due to the new pads or full break fluid?
Old Jan 21, 2011 | 12:15 PM
vtech's Avatar
Originally Posted by volvovera
i noticed a 6" diameter spot on the driveway from a fluid leak in the driver-side wheel well. And when i checked the break fluid reservoir, i found only the area around the cap is wet. The level of the fluid is above the full line.
if you did find brake fluid and the master cylinder has fluid around the cap , the reservoir probably over flowed when the pads were replaced and the pistons were pushed back in .may be fluid that leaked down from the over flow . Still it's best to remove the wheel and look closely at all brake sytem parts for leakage : Calipers , hoses , metal lines , master cylinder and abs unit . Vtech
Old Jan 21, 2011 | 12:34 PM
volvovera's Avatar
Vtech, Thank you so much for your prompt reply!
pinky
Jul 11, 2013 07:17 AM
chuckketcham
Nov 17, 2012 09:50 PM
donf
May 14, 2012 03:18 PM
ajahn
Oct 15, 2010 05:47 PM
my850turbo
Jun 27, 2006 01:29 AM
