bushing/control arm repairs
Old Aug 6, 2009 | 09:59 PM
2001s60's Avatar
Default bushing/control arm repairs
Hi,
My mechanic recently told me that I needed to change the control arm bushings. apparently its a common problem on the s60. Happened to be at a dealer the other day and he told me that its in the range of $900 to change because its labor intensive to press in and out. And he showed me that my tires are a little worn on the inside... Here's what I want to know:
- What exactly do the bushings do? Is it a safety issue, like its going to fall apart and the wheels gonna crash down or what? Or is it just a noise/tire wear issue that I can just live with?
- If I buy the control arm with the bushing installed from IPD, does that eliminate the need to do the "pressing" and thus come out much cheaper?
Thanks.
Old Aug 6, 2009 | 11:13 PM
twowheelin's Avatar
The bushings are sort of like rubber cushioned pivot points for the control arms. The tire wear and possibly suspension noises will get worse as the bushings get worse.
I haven't had to do this repair yet, but from looking at the suspension setup, it would seem there would be a lot less labor by just replacing the whole arm. You may want to check an independent mechanic and see if you can find a better price. You'll probably want do an alignment after this repair...
Osiris1975
Nov 21, 2011 07:11 PM
phoffman
Sep 2, 2007 03:07 PM
dpm2340
Nov 26, 2006 01:17 PM
dpm2340
Nov 26, 2006 12:04 PM
cathym
May 17, 2005 08:11 PM
