Can Check Engine light be caused by fuse problem?
Old Feb 3, 2017 | 01:54 PM
cochran3's Avatar
Question Can Check Engine light be caused by fuse problem?
I recently replaced the thermostat and the upstream O2 sen
sor on my 2002 S60. I understand a faulty O2 sensor can cause a catalytic converter to burn out and need replacement.
Well, the Check engine light came back on after the sensor replacement and reset.
What next? Appreciate any help.
Old Feb 3, 2017 | 02:11 PM
ES6T's Avatar
What's the fault code?
Old Feb 3, 2017 | 02:41 PM
cochran3's Avatar
I haven't checked the latest. Autozone and Advanced and a garage all agreed that the code before I changed the O2 sensor was for the O2 upstream sensor The latest(continuing) check engine came up immediately after I changed the sensor and came up after the reset.
Old Feb 5, 2017 | 09:54 PM
cochran3's Avatar
Default can check engine light be caused by fuse problem?
Error codes read(from Autozone)
P0037 HO2OS indicates that the bank 1, sensor 2 HO2S heater control circuit signal had low voltage for a predetermined period of time
Old Feb 6, 2017 | 09:31 AM
ES6T's Avatar
That is for the rear sensor. You replaced the front sensor, correct?
Old Feb 6, 2017 | 09:40 AM
cochran3's Avatar
That's right. Guess I should have realized I needed to replace both. Thanks for your response. One more thing: Is there the same urgency to replace it as the front sensor?
Old Feb 6, 2017 | 10:17 AM
ES6T's Avatar
The preheating element in the sensor is not working. So the sensor may still be reading fine, once it gets warmed up. It'll take longer though since the heater doesn't work.
Selli028
Jan 6, 2015 10:23 PM
go300mph
Jun 2, 2010 08:38 AM
New Daddy
Jan 23, 2009 04:00 AM
lukasz_T6
Dec 28, 2007 10:17 PM
JetTech
Jan 3, 2007 09:10 PM
