Car Sticking in Park
Old Oct 23, 2007 | 12:26 PM
johnnie724's Avatar
Default Car Sticking in Park
My dad's 01' s60 sticks in Park after initial start. He has an auto transmission and in order to shift to D or R, he has to either shake the wheel, tap the brake, or a combination of things. I tried searching but couldn't find any info. Possible solenoid (location??), brake booster, safety feature..........kind of at a lost and don't want to surrender to the stealership.
Also, is there a chilton's/haynes/bentley's for he S60? I can only find electronic manuals on Ebay and possibly alldatadiy. Thanks in advance.
Old Oct 23, 2007 | 05:38 PM
Default RE: Car Sticking in Park
Maybe the brake light switch or soleniod.
Or maybe also the ignition switch.
Old Oct 24, 2007 | 01:21 AM
Volvocars's Avatar
May be the cable between the ignition lock and the shift lever.Ever spill anything over your shifter? It could make the mechanism stick.
Old Oct 25, 2007 | 09:59 AM
Bazillio's Avatar
if you run out of options, go to dealer to do a diagnostic on transmission. you may need to reset transmission soft.
Old Oct 25, 2007 | 10:46 AM
johnnie724's Avatar
No they've never spilled in there to my knowledge. Looks like I'll have to disassemble the shifter assembley to further investigate the reverse lock solenoid or the ingition interlock cable. Does anyone have pics or diagrams?
Old Oct 26, 2007 | 11:25 PM
Volvocars's Avatar
If you don't know how to remove the center console to get a better look check -"cigg lighter" broken on center console, how to fix?- in this forum. I just posted there hope it helps. Sorry no pics or diagrams.
Old Oct 28, 2008 | 09:38 AM
nicolas414's Avatar
Having the same issue, also key is getting stuck in ignition. What was it?
Old Nov 10, 2008 | 08:11 AM
spacecadet's Avatar
Default RE: Car Sticking in Park & key stuck in ignition
weather changing, getting colder. I am experiencing trouble when shifting fromP into R. key isalso getting stuck in ignition. bulb light failure code appeared a couple days ago then the key stayed stuck permantly and the brake light andtail lights stayed stuck on . I assume there is a problem with the TSS solenoid or ignition barrel is ****!!!!!
Old Nov 22, 2008 | 07:19 AM
ianreid's Avatar
ah this has been my nightmare for about 2 months now... the same exact problem as above..
i put the key in and 90% of the time it takes more than 25 mins for the car to be able to shift into park. and once it does.. everything works fine.. then once i park i cant get the key out with out waiting 15-25 mins and today the battery died for the 2nd time in under a month..
has any one found the solution for this problem?
Old Nov 22, 2008 | 07:41 AM
I would check the adjustment of the cable from the ignition switch to the shifter assembly.
You might also want to spray a little silicon or something like that on the arm where the cable attaches to the shifter assembly.
MarkoParko
Apr 30, 2014 02:55 PM
stockton T5
Jul 5, 2007 03:55 PM
95 T5_R
Mar 9, 2007 09:46 PM
JimKW
Feb 8, 2007 09:40 AM
ko_kidd
Aug 13, 2006 08:27 PM
