Crank sensor issue -- NO start
Old May 27, 2023 | 05:44 PM
Cartalk2's Avatar
Default Crank sensor issue -- NO start
Car will not start, had P0336 code. Replaces crank sensor car will NOt start and throws / continues the P0336 code/
Need some help on this one
2002 - S60 - T-5
Thanks in advance.
Old Jun 3, 2023 | 08:10 PM
Cartalk2's Avatar
Update. Tried another computer, still NO start. Anyone know it the computer locking mechanism has any electrical connection. I tried to start while lock was disengaged. This locking system really leave something to be desired even with the re1quired special tool .
Any suggestions -- probably will have it towed soon.
Old Jun 4, 2023 | 09:44 AM
Originally Posted by Cartalk2
Update. Tried another computer, still NO start. .
A used Engine control unit or CEM (or many other modules) will not work in your car. They are not plug and play - they are tied to the VIN of the car.
Old Jun 4, 2023 | 07:35 PM
Cartalk2's Avatar
Thanks Hoonk, I did see a note the throttle needs to be re-computed. P0336 code (crank position) is no longer shown.
Finally answered my own question in that the ECM should be locked into position for operations. I had to disassemble the module box to get locks open, due to badly worn system, and noted the locks seem to actually pull ECM down engaging pins into position. Put old ECM back -- it was starting briefly, but now no start.
NEED help here as now going to the FPCM, but unable to locate. Supposedly the FPCM is on the passenger side, rear door area, on top of the fuel tank, but it is not there or in the trunk -- where did it go -- anyone know where to look?? Youtube has demo for metal gas tank, but I have some type of composition material and tank leaves no space on top.
Any other ideas for this NO start. Thanks
Old Jun 4, 2023 | 09:10 PM
If you don't have a fuel pressure sensor on the end of the fuel rail (and a 2002 does not) you don't have a fuel pressure control unit. You are grasping at straws - guessing at stuff that your car does not even have.
Sorry, not really sure what to suggest - Need more concrete info.
Old Jun 11, 2023 | 03:42 AM
Cartalk2's Avatar
Thanks for all comments.
Tried to keep it out of shop, but finally relented and had towed.. Between repair shop and dealership, who installed new fuel pump, it was becoming a mechanical foot ball with no goal insight -- thus was given final blessings and sent to salvage.
Sckeet05
Aug 19, 2022 08:24 PM
dws60
Jun 26, 2022 08:03 PM
Dumbwaters
Apr 27, 2022 10:43 AM
venkman
Dec 11, 2015 08:35 PM
mudpie
Jul 19, 2010 09:59 PM
