Dealer "Blowing smoke"
Old Dec 7, 2018 | 01:25 PM
Pretorien's Avatar
Default Dealer "Blowing smoke"
Problem (previously posted) + concerns about what I'm being told
Data: With no previously noted malfunctions, 2015.5 T5 V60 refused to start - just a "click" - "jumping did not help
Towed to dealer - diagnosis: starter motor failure
New starter motor - still no start
Diagnosis - oil cooler failure - water in oil causing drag & hard to turn over
Plan of action: replace oil cooler, drain & refill engine
Questions/concerns:
Being old school, the oil coolers that I am familiar with are simple "mini" radiators - looking at a picture of the Volvo unit, I see 4 connections. Is it indeed the case that the oil and coolant are both attached?
Dealer says that they will make sure that "everything is fine" - if this co-mingling of oil and coolant has caused the engine to be hard to turn over, hasn't the damage already been done? In my experience, coolant in the oil is a death sentence.
Advice?
Old Dec 7, 2018 | 05:42 PM
ES6T's Avatar
That makes no sense at all.
Old Dec 7, 2018 | 10:49 PM
Pretorien's Avatar
The only way that I can make any sense of it is to assume that the coolant in the oil did enough damage to make the engine hard to crank. This, of course brings up other questions - the car has only 46,000 miles on it. Even if it is "loosened up" enough to start, what might be the residual effects that would only surface as the miles accumulated?
Old Dec 8, 2018 | 08:32 PM
Assuming the diagnosis of water in the oil is correct and their plan of action corrects the problem, then any damage would already be done. That said, I've never heard of water in oil keeping a car from starting. Its pretty common for head gaskets to fail and people notice it by the oil frothing not a sudden no start...
Old Dec 9, 2018 | 07:31 AM
firebirdparts's Avatar
It's curious to say the least. Seems like working you over for the cost of an oil change wouldn't make much sense, though.
Old Dec 9, 2018 | 10:54 AM
Pretorien's Avatar
No cost - it's all under warranty ("Certified" car)
Old Dec 10, 2018 | 05:25 AM
Well, if you do need a new engine, I guess they can put one in.
But to answer the root question, coolant mixed with oil provides plenty of lubrication to start a car. The car would never be seized from that. I'm sure they'll figure it out.
Pretorien
Dec 22, 2018 12:58 PM
cberry
Jan 16, 2018 11:51 AM
sstewart0974
Jun 29, 2010 09:51 PM
Roge
Mar 17, 2008 02:23 PM
clajeunesse
Dec 30, 2007 01:48 AM
