The door of the fuel tank doesn't lock!!!
Old Jun 1, 2007 | 12:31 PM
almared6's Avatar
Default The door of the fuel tank doesn't lock!!!
Hi all,
I just found out that when I lock my car the door of the fuel tank doesn't lock. I dissembled the lock from the inside and when I tested it using a power converter at home, it worked for both locking and unlocking. It seems that the problem is a wiring issue because when the lock is installed in the car, it only unlocks . There are only two wires connected to the electric locker. I used a power checker (small equipment that tells you if there is electricity going or not) and when I unlock the car it gives me a signal that there is electricity on the wires and I could see the lock tries to unlock but when I lock there's just nothing. There's basically nothing wrong with the wires themselves but with the lock system. How to check the lock system and where is it?
Old Jun 1, 2007 | 01:35 PM
billofdurham's Avatar
Default RE: The door of the fuel tank doesn't lock!!!
This is where it is. It seems an easy job to remove it for testing.
[IMG]local://upfiles/4491/CDF382D838A545E9A496FAAFC62CB557.jpg[/IMG]
Old Jun 1, 2007 | 01:48 PM
almared6's Avatar
thanx but the problem is not with the lock itself. when I unlock the car the lock unlocks but when I lock the car it doesn't lock. I remvoed the lock and tested it and it works perfectly.
Here's the lock after I removed it
I said before that there are 2 wires and when I unlock it works but when I lock it doesn't so it's niether from the lock nor from the wires. I know that my problem is diffecult but I'm hoping you could help me.
I think the problem is from the place that controls the locks or maybe it's a fuse!!!
Please help
Old Jun 1, 2007 | 02:12 PM
01_fast_ride's Avatar
Interesting problem. I initially thought a relay was the culprit as well. You say it unlocks with the rest of the car but does not lock. Suggests to me that it could very well be a bad locking relay. I remembered reading about the fuse panel located in the trunk (drivers side). I found a great diagram to help you locate the problem. See if its indeed the relay or perhaps a loose wire nearby.
Diagram of rear fuse panel: pulled from another thread
locate RMI1 for the locking relay
https://volvoforums.com/upfiles/4491...CC4D364C99.jpg
That's my guess. Let us know your findings.
Old Jun 1, 2007 | 02:19 PM
almared6's Avatar
Thanx very much fast ride and billofdurham for this great support. I left my car at work today and tomorrow I'm going to it and I'll check the fuse panel and let's hope that it's just a fuse and not the entire locking system.
As soon as I check it tomorrow I'll post here.
Thanx again.
Old Jun 2, 2007 | 11:10 AM
Before you spend more time digging through your car, check one more thing out. I spent a little time digging through VADIS. It seems that the fuel door has a delay built in. It waits 10 minutes before locking the fuel door assuming you lock the car using the key or remote (the switch on the doors may not do it). So try this out.
Old Jun 2, 2007 | 11:16 AM
almared6's Avatar
So you're saying that when I lock the car the locker of the fuel tank waits 10min to lock. That's very interesting because I never checked the fuel tank before I unlock the car so it may be the problem. By the way, I checked the fuses today and they are all ok. I'll to check if the fuel tank is locked or not next time I go to the car but If this is what you implied on your last post, is it the same in your car? I mean when you lock the car do you have to wait 10 min for the locked of the tank to work?
Cheers,
Old Jun 2, 2007 | 11:53 AM
Yes, it is the same with my car. I went out to it, checked and the fuel door was locked. Unlocked it, door was unlocked. Locked it again, door remained unlocked. It will lock after the delay.
Old Jun 2, 2007 | 12:01 PM
almared6's Avatar
if that turns out the same with my car, then it would be hilarious!!! I never thought of that and I can't wait to check it because it's a very big issue for me to have the tank door opened all the time. I'll for sure post here after I check it.
Thanx fast ride and I really really appreciate your help.
Old Jun 4, 2007 | 04:46 PM
almared6's Avatar
I checked the door of the fuel tank today before I unlocked the car and thank God it was locked . I almost disassembled my car for it!
Thanx first ride, without your last post, I would never have figure it out
Old Jun 5, 2007 | 09:43 AM
Good stuff. One last post. I found this while looking for something else. It seems that the fuel door has an option (choice) to lock immediately. I assume it is a dealer SW change, but for anyone who cares:
from VADIS regarding Programmable Customer Parameters:
Time delay, locking the fuel tank filler cover
The time delay between the car being locked using a remote control or the key until the fuel tank filler cover locks can be programmed. There are two alternatives:
-10 minute time delay
-0 minute time delay.
The time delay when locking the fuel tank filler cover is programmed via the vehicle communication socket under function group 3, Central electronic module (CEM), Programming customer parameters.
Old Jun 5, 2007 | 03:03 PM
almared6's Avatar
sounds nice but I'm satisfied with the 10 min . Better than never working!
Old Jun 11, 2007 | 12:02 PM
tocopan's Avatar
hi guys,
i read on the owners manual of my 2007 S60 and it says that when you unlock the fuel door, it will lock again when you startmoving the car at 10 mph or something like that. It was a security for i don't remember what.
Old Jun 11, 2007 | 03:56 PM
almared6's Avatar
I can't think of any reasons, you could still wait for first ride and he'll give you the answer for sure ;-)
Old Jun 11, 2007 | 05:57 PM
thanks tocopan, you are correct on this. Models which have the remote fuel door release on the dash work in the way you have described. From the description that almared6 gave about his situation, I believe his car is like mine and does not have this button and the fuel door locks after 10 minutes.
Old Jun 11, 2007 | 11:00 PM
tocopan's Avatar
it makes sense.
thanks
Old Feb 8, 2008 | 09:34 PM
  #17
garrisos101's Avatar
That was a great tip 01_fast_ride. Thank you!!!
Old Dec 19, 2008 | 06:00 PM
  #18
grosseile88's Avatar
Thank God I read these posts before I tore my fuel door apart! My 2001 V70 has the same delay, no mention of that in the owners manual!
Old Feb 5, 2013 | 08:35 PM
  #19
Johnny Hamm's Avatar
Fast ride rocks!
qcvol
Jun 17, 2013 09:55 PM
mat1t
Mar 14, 2013 11:14 AM
the_happy_driver
Jun 26, 2008 12:47 AM
rcalhoun
Jun 3, 2008 09:48 AM
malibu323538
Feb 13, 2008 05:45 PM
