Emissions service required reset
Old Sep 19, 2005 | 05:04 PM
merlin's Avatar
Default Emissions service required reset
I have an S60 2.4T. I'm getting a check engine light, and an emissions service required message in my message center. All my maintenance is up to schedule. Is there some way I can reset this light and message. Thanks so much to anyone who can save me a trip to the dealer.
Old Sep 20, 2005 | 01:28 AM
Default RE: Emissions service required reset
That light coming on means there is a fault in the system.
You will need to have it looked at by someone.
Old Oct 11, 2005 | 11:35 AM
Coffey's Avatar
I've had this Emissions Service Required message along with the Check Engine light appear off and on since January of this year.
The Volvo dealer where I get my car serviced (2001 S60), said it is a 'possible' air flow meter problem. However, the air flow
meter was replaced this summer, unfortunately by a non-dealer. Now, my car won't pass inspection, and the Car Care Center
that performed the inspection gave me a different code for the emission message -- has to do with the catalytic converter.
Thursday, the dealer will take a look at it again and hopefully this can be resolved. Anyone else experienced this kind of problem?
BTW, Repair since the beginning of the year on this car is now over $1500.00 including cleaning the ETM. I don't want to give up my car, but if problems persists, I may have no choice. Over 80K miles (commuter car). I'ved owned a Volvo before ('90 740GL) -- NOT ONE PROBLEM with that car -- I loved it.
Thanks for your attention,
Coffey
Old Oct 11, 2005 | 11:39 AM
fire2havoc's Avatar
Get it checked out by a mechanic. In my case, this message means a sensor problem. However, that is not the case. Most importantly, you need to make sure that no vital gases are leaking from your engine. Also, if you do not turn this off, you will not pass smog check.
Old Oct 11, 2005 | 02:29 PM
Coffey's Avatar
Thanks, I have an appointment with the local Volvo Service Dealer on Thursday.
Coffey
Old Oct 11, 2005 | 09:03 PM
Also I know some of the turbo cars require a software download when installing the mass flow sensor.
You might want to ask about that as well.
Old Oct 12, 2005 | 10:09 AM
Coffey's Avatar
TEch,
My S60 is not turbo, but thanks for the reply. By the way, I had to get gas yesterday, filled up and the message went away along with the Check Engine light. You think it will pass inspection now? (I'm still taking it in to Volvo tomorrow)
Coffey
Old Oct 12, 2005 | 11:28 AM
fire2havoc's Avatar
Have them check it out just to make sure. Periodically, I ge the message "fuel cap loose-open." The problem might have gone away but it may also return.
Old Oct 14, 2005 | 04:40 PM
Coffey's Avatar
Update:
Volvo Service diags resulted in catalytic converter problem. It has to be replaced. Luckily, I told them about this problem during the 75K service, but they did not run the diags then, so they will cover the cost of the replacement($1300.00). Over 80K now.
Whew!
Old Oct 14, 2005 | 10:17 PM
Good for you that they stepped up to the plate and paid for it!!
acoechow
Jun 25, 2014 03:22 PM
VJZ
Jun 28, 2009 09:54 PM
chrissygm
Sep 30, 2008 05:53 PM
Gonzo
Jul 25, 2006 03:56 PM
jefflewis1999
Feb 14, 2006 08:48 PM
