Fixing the knocking from bumps
Old Apr 3, 2009 | 10:59 AM
Metcalfe's Avatar
Default Fixing the knocking from bumps
Hello, i've got a knocking when coasting over bumps and am guessing its either the swaybar links or tie rod ends. is there a tell tale sign when i pull the wheel of of that it is thats making the noise? woul either of those things be loose? (i.e. i cna move them with my hands)
Cheers!
Old Apr 4, 2009 | 09:23 AM
Spring seat could be bad as well. Or the control arm bushings might be bad. Inspect everything good.
Old Apr 4, 2009 | 08:48 PM
Metcalfe's Avatar
Will i be able to notice anything right off the bat. missing broken parts?missing rubber bumpers? any insight would help.
Thanks
Old Apr 4, 2009 | 08:53 PM
You should see the bushings broke if they are bad.
Take a wrench and try to turn the top strut nut. If it spins freely it is bad. If it feels rubber and bounces back it is good.
Old Apr 6, 2009 | 12:57 PM
dava111's Avatar
I have the same problem on my s60. Its the front drop links on mine and I just got a pair of new ones off ebay for £15 and it looks quite easy to replace them. If it is these for you make sure you change both as a pair because when one fails the other isnt far behind.
If you put full lock on and have a look near the suspension theres a "rod" about 1 foot long with two bolts on either end.
Hope this helps!
Faceball
Jan 12, 2014 02:40 PM
LOVEvolvos
Apr 24, 2012 10:36 PM
chimmychong
May 14, 2008 04:30 PM
smc22
Feb 4, 2007 12:10 AM
ripleydog
Jan 31, 2005 01:26 AM
