front end noises
Old Nov 11, 2008 | 11:01 AM
D_Jack's Avatar
Default front end noises
ok so now that it is getting colder here i have noticed almost unbearable noises coming from my front end.. i have narrowed it down to the lower and upper A arm bushings as they have play in them and rattle when i have it jacked up and kick the tire.. i have read of people getting prothane bushing for their a arms and sway bars to eliminate these rattles and screeching sounds but thye never site where they get the bushings.. any help would be awesome this is driving me crazy as i drive on gravel roads a lot
Old Nov 11, 2008 | 03:28 PM
TIPSP's Avatar
Got Boost?
Default RE: front end noises
http://www.vivaperformance.com/catal...roducts_id=389has poly for AWD...
Check this link out for more aftermarket volvo sites: https://volvoforums.com/m_38606/tm.htm
You can always make your own Poly bushing: http://forums.turbobricks.com/showth...light=DIY+Poly
Check out http://polytek.com/ for liquid poly.
As far as endlinks go...http://www.quickbrickmotorsports.com/prod_endlink.html
Old Nov 11, 2008 | 04:06 PM
D_Jack's Avatar
sweet thanks for the links your my hero!!! now to order and spend the rest of my lifeinstalling them
Old Nov 11, 2008 | 06:24 PM
TIPSP's Avatar
Got Boost?
[sm=roll.gif]
Have fun. Good Luck.
Edit: If you do get the QBM endlinks ($$) then you should get the boots they sell...It will protect the spherical bearings from the hazards on/from the road and keep them from rusting.
Old Nov 16, 2008 | 06:22 PM
D_Jack's Avatar
ok so today i was looking and who ever had the car before me had alredy replaced those sway bar mounts... soo i started troubleshooting and found that the right strut made the scratching sound from the top rubber type piece .. so i sprayed some penetrating oil down the strut and rust came out.. it helped but didnt eliminate the noise.. so out of curiosity i turned the rubber piece on the top of the strut a few times bounced the car again and the noise went away.. just updating for anyone else that is experiencing the scratching sound coming from the struts... also for the vets with these cars and the techs which struts would you guys suggest for decent price..
Old Nov 17, 2008 | 01:04 AM
TIPSP's Avatar
Got Boost?
Are you going for stock replacement or preformance...
http://www.ipdusa.com/Volvo-S60/Suspension-&-Steering/Shocks-&-Struts/c-1-74-404-508/
Stock replacement: Sachs is OEM (I think)
It will be ~$530...if you do it yourself.
Preformance Replacement: I like Bilstein but KONI is good too.
It will be ~$600-$750...if you do it yourself.
Wing0
Dec 13, 2013 02:39 PM
rc51kid
Jul 6, 2013 05:15 PM
usedvolvoowner
Jun 14, 2010 10:00 PM
Bruno937
Mar 8, 2009 12:41 PM
