Fuse box location for 2021 V60
I just got a recall letter for changing the fuel pump fuse from 15 to 20A. According to the manual the fuse box is in the outside wall of the passenger footwell. Easy enough!? The only thing I see there is a small ~1.5" plastic cover and when you remove it, it has a single removable connector about the size of a USB thumb drive , which I have no idea what that is for, but not fuse box in sight. I know there are two more boxes , one in the engine bay and one in the rear cargo area.
can some one tell me where the fuse box containing the 15A fuse for the fuel pump is located being that I cant find it?
Do you need to remove any trim to pull the carpet back?
