which gear oil? transfer case? diff's?
Old Dec 13, 2011 | 10:14 AM
hotrodln's Avatar
Default which gear oil? transfer case? diff's?
ok my owner's manual doesn't list fluids for the diff's or transfer case...i guess they assume the owner will just let the shop do it for them..my local autoparts store lists just "gear oil"....for all. some diffs have clutches which require a friction additive.....what do you guys use in your cars?
Old Dec 15, 2011 | 05:40 PM
hotrodln's Avatar
ok i guess nobody checks their diff's? I'll have to break down and order a factory manual . I thought volvo guys worked on their own cars....
Old Dec 15, 2011 | 07:30 PM
MYS6T's Avatar
Volvo uses their own "fluid" Im sure it just re-branded Mobil or some other company's but here is what they have for My car...
For AWD
Angel Gear Angle Gear Oil
AWD Rear Diff Volvo Rear Differential Oil for AWD models
Trany Mobil 3309 ATF Automatic Transmission Fluid (Quart)
I recommend that using IPD site Set Cars year and model the site work well and i have not found any problems ....
Old Dec 15, 2011 | 08:38 PM
hotrodln's Avatar
hey thanks! looks like just gear oil in the end! i already took care of the tranny...used toyota fluids....i didn't see any drain plugs up there...is there? or do you need to suck the fluid out? i've done that before....
Old May 10, 2012 | 02:22 PM
ben watson's Avatar
Be Careful what you do use dude as ive just wrecked a angle trans i been told volvo own coz it has the proper aditives also the proper weights
Old Mar 26, 2021 | 04:42 AM
bobajob's Avatar
Default oils
hi all
silly q--but is the oil in the diff the same as in the front transfer box on my 2000 mk1 v70r awd--only had some sites selling oil as for diff / transfer box ??
any help would be good thx
Psaboic
Sep 20, 2022 02:30 PM
RJSV70
2001-2013 model year XC70
Apr 16, 2017 03:25 PM
drenman
Sep 27, 2015 08:50 PM
karajan
Oct 3, 2014 05:45 PM
petes99xc
Oct 26, 2008 07:59 AM
