Hard Starting
Old Dec 20, 2012 | 11:44 AM
odbii's Avatar
Default Hard Starting
Still continuing to have starting problems with my 2007 S60 2.5T. It occurs at random times and every once in a while it shows "Reduced Engine Performance".
Replaced fuel filter.
Here is a video of the problem I'm having. This is not my video but one I found of a similar S60 that sounds just like mine.
Old Dec 21, 2012 | 05:15 PM
01_fast_ride's Avatar
There are several things that can cause that message but some of the more common reasons are the ETM (throttle body) and the MAF sensor. There is a chance it could be the Crank Position Sensor (CPS). I would begin by cleaning the ETM and MAF. I would also disconnect and clean the terminals (wire harness). The CPS signal might be inconsistent. It may not be a bad sensor but a bad connection or faulty wires somewhere. My brother's C70 is that way. He had the CPS code along with no starts, I replaced the sensor and it worked - for a while. It still has an occasional no start. He found that just by re-adjusting the wires to the sensor it fixes it until the next time it happens.
daver80
Jul 13, 2009 10:19 PM
marclou1969
Sep 27, 2006 08:52 PM
jerryman
May 23, 2006 01:19 AM
Sapient
Apr 10, 2006 10:40 PM
penkogj
Nov 30, 2005 08:07 PM
