Heater blowing cold warm intermittently
Old Nov 27, 2018 | 12:01 PM
DanaT's Avatar
Default Heater blowing cold warm intermittently
2004 s60 AWD. HEater blows cold air most the time, then warm, and back to cool. Temp guage at 12:00. Mechanic says it's thermostat and he measured temp at 120' and guage not right.
Had a new thermostat and housing 2 years ago (10,000 mi +-)
Thing is, temp switches quickly with no observable change in guage. Radiator fan continues working for short while after shutting off engine showing it's still cooling down.
I nsuspect something going on in the sensors or climate control. Don't want to put in another $365. Thermostat if not needed.
suggestions?
Old Nov 27, 2018 | 04:13 PM
Pretorien's Avatar
$365 thermostat? What are they made of - gold/platinum bi-metallic leaves? Now, I'll admit that it has been a long time since I changed a thermostat but I recall two bolts, a 50 cent gasket and maybe a $5 part.
Old Nov 27, 2018 | 04:17 PM
DanaT's Avatar
It only comes with a complete replacement housing. The part coast about $165. The labor was around $250 which I don't understand at all. Even if they have to remove the power steering pump to access it, it should take that long.
online search on total cost range from $250-$500. I'm tempted to try it myself.
Old Nov 28, 2018 | 11:10 PM
Did you check the coolant temp sensor? you can measure its resistant cold then again hot. Google for appropriate values.
Old Nov 29, 2018 | 07:49 AM
DanaT's Avatar
i know the coolant temp sensor is malfunctioning as I frequently get the warning message for low coolant level, even when full. Does this feed into the function of the heater?
Old Nov 29, 2018 | 07:54 AM
DanaT's Avatar
I'm surprised I can't find any info anywhere diagnosing the heater flap doors function. The heater will work briefly then back to blowing cool air rather quickly. Faster than I could imagine being affected by the thermostat.
This morning I will let thme car run and put my hands on the heater core hoses to evaluate. I can also measure the coolant temperature in the overflow tank with a thermometer.
Old Nov 29, 2018 | 06:56 PM
the coolant level is measured by a float in the overflow reservoir. The engine coolant temp sensor bolts into the thermostat housing - follow the upper radiator hose back to the block and you'll see the sensor right under the cap that the hose goes to. This sensor feeds the ECU and the temp sensor on the dash but I am not sure if it has a role in controlling the HVAC doors. Do you ever see blinking lights on the AC/REC buttons? (that's the climate control computer saying it has a fault code.)
Old Nov 29, 2018 | 07:04 PM
DanaT's Avatar
No blinking lights.
Today I ran the car till temp guage read normal (12 o'clock). Heater still blowing cool air. Put a thermometer in the overflow tank and got reading of about 120'.
Hoses in and out of heater core very cool. Heater hose from thermostat to radiator hot.
Reved engine to 2k for minute or two. Heat began coming thru but returned cold when back at idle.
So, seems like heater core working, heater flaps working, but not reaching temperature. Looks like it needs another thermostat again?
akimball442
Apr 5, 2015 10:42 PM
majik455
Jan 29, 2014 03:50 AM
NoM54Me
Dec 10, 2012 06:39 AM
hackwrench
Feb 5, 2011 07:38 AM
skyman
Apr 9, 2006 01:25 AM
