Help re: remove replace blower motor resistor 2011 S60
Old Jan 6, 2018 | 11:25 AM
monza's Avatar
Banned
Default Help re: remove replace blower motor resistor 2011 S60
My blower motor started acting funny. would cut in, quit start up again intermittently. Then would only work at full speed setting but would/might would only occasionally work at a lower setting, while still having the cutting off and on symptoms. It has now died and will not come on at any setting. This suggests its the resistor as the fan worked fine if it was getting power.
I need to know the blower fan resistor location and reoval/replacement procedure.I wouls think it should be an easy task. Just need to know where to start.
If anyone has experience with this issue and resistor replacement, any advice would be appreciated.
Old Mar 1, 2018 | 08:14 AM
monza's Avatar
Banned
Default bump Help re: remove replace blower motor resistor 2011 S60
skarim
Aug 29, 2010 01:49 PM
jmallie
Sep 17, 2009 09:47 AM
Evo 850
Jan 2, 2008 08:50 AM
Evo 850
Dec 6, 2007 01:51 AM
Evo 850
Nov 24, 2007 05:25 PM
