how can I mess up a fuel door hinge install??
Old 10-11-2018, 08:49 PM
John Roden's Avatar
Default how can I mess up a fuel door hinge install??
The IPD video told me to snap off the plastic pins on the outer side of the hinge then knock the river it with a punch. Should the punch be larger than the diameter of the pin? I made a hash of it and had to order a new one. Any tips on this seemingly simple job appreciated
Old 10-11-2018, 09:35 PM
ES6T's Avatar
1- Install the hinge on the fuel door.
2- Position it on the car. Use a hammer to secure it with the top and bottom plastic pins.
3- Remove the middle pins with needle nose pliers
4- Use a pick to make the holes for the middle pins just slightly bigger.
5- Put the middle pins back in the holes and push them in fully
Old 10-12-2018, 05:03 AM
John Roden's Avatar
At the risk of being a dope, explain step 2. Just tap them with a drift?
Old 10-12-2018, 07:34 AM
ES6T's Avatar
However you want to do it is fine. I use a hammer.
yoyoman
11-28-2012 09:41 PM
Simtech
01-31-2012 07:32 AM
hubmachine
07-09-2007 05:03 AM
beachguy82
08-29-2006 08:52 PM
jefhon2112
04-13-2006 12:03 PM
Quick Reply: how can I mess up a fuel door hinge install??
