Idle problem
Old Sep 25, 2007 | 04:52 PM
NCS60's Avatar
Default Idle problem
I noticed when my AC is running that my car almost stalls everytime the compressor cycles. Basically I can hear the compressor cycle and when it releases the rpms pull down about 300. The engine adjusts by adding more rpm for a second then it goes back to normal. I understand that the AC will pull from the engine and the computer should adjust for the fluctuation but it pulls down low enough (<1 second) to shake the car a you can feel almost cut off before catching back up. My car is an 01 2.4T with 123K miles.
Any ideas?
Thanks for the help!
Old Oct 3, 2007 | 09:16 PM
JPN's Avatar
JPN
Default RE: Idle problem
Sorry about the problem.
As you have described, the idle boost system may be having a minor problem. Since I am not privy to the S60s, I would visit an independent shop that specialises in Swedish.European makes (make sure that theyhave "ASE-CERTIFIED" poster outside/inside the shop). Or, visit a dealer and tell them exactly what want them to do (e.g., "The idle boost system seems to be allowing the RPM to drop excessively when the A/C is on so please check the cause-and please don't try to sell me a new compressor because my car doesn't need one[8D]")
If you're handy with tools and have good knowledge, I would consider getting a service manual too.
And see if other S60 owners reply to your question.
I wish I could help you better.
JPN
Old Oct 4, 2007 | 12:27 PM
NCS60's Avatar
I actually ended up posting the question on swedespeed & volvospeed and got a few options. It appears that it may be the ETM on it's way out. I cleaned the MAF and that didn't help anything (although it was good to do anyway). After looking at the problem a little closer, the idle actually drop too low when coming to a stop but quickly catches up. This occurs with the AC on and off BUT it is worse when the AC is on. I don't think it is the compressor at this point because of the other symptoms. It appears it may be a ETM problem (I have an 2001 and we all know about the ETM problems[:@]) or PCV concern.
I do most of the work on my Volvo (and my other vehicles) but it appears this one may have to be diagnosed at the dealer. Then I will decide if its worth fixing myself or paying for the labor. I wish the S60 had a "normal" repair manual like the previous Volvo's (to bad Volvo's have changed so much )
Thanks for all the help
Old Oct 6, 2007 | 08:17 AM
Try cleaning the throttle body first before taking it anywhere.
Sorry would have replied earlier but have been really sick.
rosesforlily
Nov 5, 2009 09:23 AM
kevmcrae
Apr 25, 2009 11:25 PM
yank50
Mar 14, 2009 11:15 AM
ss~zoso~ss
Jan 12, 2009 04:27 PM
toshields
Dec 8, 2007 04:50 PM
