intermittent A/C problem
Also see this post about it.
https://volvoforums.com/forum/volvo-850-16/c-compressor-clutch-reshimming-6665/
When the center part of the clutch is installed there is washer looking things between the center part and compressor. There is usually 2 in there and I always remove the thicker one and install the smaller one and that fixes it.
https://volvoforums.com/forum/showthread.php?t=6665
intermittent and the exterior temp gage drops
We have noticed over the last 1.5 months, and this very hot summer with a black car, that our a/c is going on and off. Usually for 10 min. at a time at least. It tends to kick back on. It happens anytime of the day. We realize it because the air is warm coming out of the vent, but we also notice that the exterior temperature gauge on the dashboard drops to 22 or 25 degrees Fahrenheit. It will go up and down and then once the a/c kicks back on, it starts to record an accurate outside reading.
What does that tell you about our problem?
Can anybody help me out on this one?
schuckles
01-30-2010 01:44 PM
