Just purchased a used s60 need some advice
Old Jan 12, 2016 | 10:48 PM
Volvoandy's Avatar
Default Just purchased a used s60 need some advice
Hi folks, my first post here..... I just purchased a 2002 s60 awd with a 140,000 miles on it.... I love this car and I know they have issues but I have faith in the car, so..... Here we go, the dash cluster only works intermittently, and when it goes out nothing works at all in the cluster, and then when it wants to, it comes to life..... The key fob that I was given with the car does not work, tried replacing the battery to no avail..... And the sunroof doesn't work at all...... And lastly I have a vibration that is only present when I'm applying the throttle at highway speeds, let off the throttle and no vibration.... Any tips or help with these issues would be greatly appreciated!! Thank you in advance!!!
Old Jan 13, 2016 | 06:55 AM
RA082324's Avatar
Banned
The first part, look up DIM repair on here, it's a known issue. Can't speak on Sunroof or key FOB except check your fuses for related systems.
The last part, I have the same issue and have a bad outer tie rod in the front, give that a check.
Old Jan 14, 2016 | 12:31 PM
Koondaddy's Avatar
hey, i have a 06 s60 and i was feeling vibrations when in high rpms or on fwy, started off intermittent then got worse. after a few weeks it started vibrating while braking to then id let off and it was fine. turned out my front axles were shott. paid almost $2,000 for new oem axles. (which i took to a volvo specialist) used or aftermarket are alot cheaper but ive heard bad things. goodluck to you
Old Jan 27, 2016 | 07:16 AM
to the forum VolvoAndy
You might want to put a location in your profile.
If you're in the US, you can take the keyless entry transmitter to an Oreilly or Autozone and have it tested to see if it's sending a signal. That would narrow it down to the transmitter or something with the car or it needed to be programmed.
Old Jan 27, 2016 | 12:24 PM
Volvoandy's Avatar
[[/B]
Thank you so much I'll do that!!
missthe122
2001-2013 model year V70
Sep 1, 2013 09:34 PM
Abacusvolvo
Jan 19, 2011 10:26 PM
Homoudont
Jan 12, 2008 07:42 AM
Diana.RO
May 9, 2007 06:07 PM
willko1
Jan 17, 2006 10:28 AM
