Loud squeal from right front: Driving on Snow/Slush
Old Dec 7, 2005 | 10:30 AM
VinUnleaded's Avatar
Default Loud squeal from right front: Driving on Snow/Slush
For the first time I drove on a thick layer of slush this week.
The car was fine, but about a a quarter way home, I heard a loud noise like someone raking their finger nails across a blackboard.
I was only going about 20mph on a flat surface, when it first did it.
The other 2 times was on a slight downhill grade.
I was not using my brakes in all 3 instances, just coasting.
It last about 5 seconds, and did it two more times over the span of 15 minutes.
However, for the next 45 minutes and since then, it has not done it.
I will have to see this Thursday and Friday when it snows again if I can duplicate.
Sounded like a train when it comes to a stop and makes all kinds of metal screeching brake noise.
Like I said, it has not done it since...
Any ideas?
Old Dec 7, 2005 | 07:00 PM
Default RE: Loud squeal from right front: Driving on Snow/Slush
Make sure your car has the lower engine cover on it. It bolts to the middle of the subframe.
Sometimes if the car doesn't have it and water/ice gets in there it will make the belt slip.
Old Dec 9, 2005 | 03:16 AM
gordon368's Avatar
sometimes when i accelerate on the slush and it slipps, i get that raking sound, and its always my STC, or the traction control.....
Old Dec 29, 2005 | 01:37 PM
aalleoxn's Avatar
I too had this problem and took the car in. Apparently there is a TSB on this. Snow building up on the exhaust and weighs it down pushing it up against the driveshaft. They installed a 'spacer' kit and it went away. This may be your situation.
Regards,
Alex
2004 S60 2.4T
ced
Feb 13, 2010 03:55 PM
sethgoodwin
May 1, 2009 09:00 PM
BlackC5
Feb 17, 2008 07:00 PM
amcdonal
Apr 20, 2007 01:07 PM
rmclemns
Aug 25, 2005 09:15 PM
