Low Beam Headlight problem
RE: Low Beam Headlight problem
ORIGINAL: 99VolvoV70
I'm not sure about these cars but usually you just push the bulb in and turn it until it pops out.
Also, yes, I unhooked the wire latch that holds the bulb in. The problem is specifically pulling the bulb out of the brown socket plug thing. It just wont come out when I pull. Its looks like it should just come out like you are unplugging any electrical device, as the lightbulb has 2 flat prongs that go into the brown socket.
Yes they should unplug. But seems almost like a little kid designed the connectors for the light.
Actually there is little tabs that lock the connector to the bulb. But you can't see them because they are under the brown plastic.
Usually if you pull pretty hard it will just unplug.
Volvo_Neps
1998-2000 model year V70
10-07-2013 10:28 PM
Volvoguy505
09-11-2010 05:53 PM
