need answer to my car
hi, i bought a 2001 s60 2.4 turbo with 40k on the car and today the car make noise when i turn left or right. Also need a fog light kits for the car, i am locate in Toronto Ont. the dealer here sell it for 210 plus 13 % tax. I need to change the transmission fluid but there is no mobile 3309 here so which fluid should i use. i appreciated for the replies.
thx for the reply, I think i'll buy the fog light from the dealer but i don't know how to stall the light, should i let the dealer do it. the noise was from low power steering fluid. I fill it up with the dealer fluid. but some time when i turn the noise still there but a lot less. Maybe i'll drive to Buffalo to buy the mobile 3309. does walmart or Kmart have it in the state.
If you're adding foglights because your car didn't come equipped with them, then yes, have the dealer put them in. It will require a software download to activate the switch (dealer-only). As far as the fluid, your best bet may be to search online for a nearby mobil distributor.None of the auto stores I've been to carried it. If you are in a bind, Toyota sells a fluid that is 3309 and you can get it at the service/parts department much cheaper than genuine Volvo fluid. But I would only do that if you have trouble finding the mobil stuff.
Go to the local Toyota dealer for the transmission fluid. Ask them for Toyota T4 atf fluid, at about $6-$7 a liter. This fluidis J3309 spec. Your Volvo has a Japanese Aisin Warner (Toyota)transmission.
Volvo $20.00 a liter fluid does not have any magical qualities and is not even synthetic at that price, regardless of what some people might think or the dealer tells you. Just check the MSDS sheets and you will see it is regular liquid dinosaur remnants.
KellyW.
07-11-2016 12:03 PM
carol123
10-09-2012 06:40 AM
KellyW.
06-29-2008 09:50 AM
