Newbie mod ?
Old Feb 10, 2006 | 10:48 AM
Chrisdaddy's Avatar
Default Newbie mod ?
Hey everybody,
I just bought a beautiful 2002 s60 2.4 non turbo automatic, and I was wondering if anyone could help me find some horsepower/torque gains. I am looking for a list of parts with the gains, or a good search topic.
Every time I do a search all that shows up is turbo modifications. I might put a turbo in her one of these days, but for now I am looking for bolt on's. I am not looking to drag race just more power.
Thanks,
Chrisdaddy
Old Feb 10, 2006 | 03:37 PM
S70driver's Avatar
Default RE: Newbie mod ?
Ok well there isn't much really for you.
1. Intake K&N panel filter is the best bet and or a K&N cone filter on the end of your MAF. Youw ill gain nothing but possibly 3hp.
2. Exhaust, 2.25" to 2.5" piping with a Magnaflow muffler on the end, you might gain 10hp at the most.
3. Nitrous, be careful. You can and will blow your engine if used in the wrong manner and using too high of a shot.
4. You could try a N/A ECU upgrade, it might give you 20Hp, but I doubt it. Check into RICA, Upsolute and Speed Tuning USA for other possible ECU upgrade. Speed Tuning if they have one for you, will be the cheapest, then Upsolute, then RICA being very exspensive.
http://www.ipdusa.com
http://www.eurosporttuning.com
http://www.vptuning.com
http://www.volvomotorsports.com
Old Feb 10, 2006 | 03:44 PM
S70driver's Avatar
Here are some mods from those sites.
IPD USA STUFF
1. S60 FWD & AWD 2001-06 not R Heico sport exhaust FWD models WSH2521603 $999.00 40.0000
EST STUFF
1. K&N Replacement Air Filter
K&N Replacement Air Filter Quantity in Basket:none
Code: VLE-160-101
Price:US$55.95
Shipping Weight: 1.50 pounds
Promotion Code:
Quantity:
Performance K&N Air Filter replaces your original air filter with a K+N air filter your Volvo will have improved performance from the free flowing and less restrictive design. Flow bench testing shows an increase in airflow over the stock paper air filter. K+N filters save you time and money over the life of your Volvo.
2. S60 2.4L 2001 - 2004 ECU Upgrade
S60 2.4L 2001 - 2004 ECU Upgrade Quantity in Basket:none
Code: VLE-265-070
Price:US$640.00
Shipping Weight: 10.00 pounds
Promotion Code:
Quantity:
Performance engine computer upgrade for your S60 2.4L improves engine torque and horsepower. The increased power provides your Volvo with very good performance and driveability. The fuel consumption is the same as original when not using the additional power and torque increase and using the same fuel quality.
VMS STUFF
1. VMS High Performance Motors
[VMS-2.3/2.4] $8,499.00
Click to enlarge
This is what is include in one of our VMS Performance Motors
1 set of VMS connecting rods
1 set of ross pistons 8.5 to 1 compression ratio
1 Fully machined crankshaft
1 set of chrome moly performance rings
1 set of performance rod bearings
1 set of performance main bearings
1 new oil pump
1 new water pump
1 timing belt
1 complete set of cryo treated valve springs
1 fully ported and polish performance cylinder head
1 set of ARP head studs,nuts and washers
We do all of the machining such as boring,honing,balancing the rotating
assembly,adjust valve timing for optimal performance,check and resureface
deck of engine block and cylinder head. pressure test cylinder head.
Prelube and ship to you.
Old Feb 11, 2006 | 04:18 PM
S60 R's Avatar
All depends how much u want to spend. The ECU ugrade would give u the most power since u dont have a turbo. Theres a list of aftermarket companies in the general forum, but Ive had great dealings with Evolve.
http://www.evolvecars.com/site/index...86,136,0,0,1,0
And another suggestion;
http://www.partsforvolvosonline.com/...ath=28_270_419
Old Feb 11, 2006 | 04:21 PM
S60 R's Avatar
Another suggestion, although they dont sell downpipes or catalytic converters;
http://www.heicosportiv.de/mainframe.asp?lang=gb
Old Feb 11, 2006 | 11:29 PM
Chrisdaddy's Avatar
Thanks everyone for the info.
Chrisdaddy
VolvoPower850r
Nov 27, 2009 07:40 PM
Osmenthe
Jul 20, 2006 05:53 PM
snowman2109
Oct 14, 2005 02:34 AM
Hoopy
Jul 21, 2005 11:36 AM
Liz_XC70
Feb 16, 2005 11:49 PM
