Noise when moving side to side
Old May 26, 2010 | 07:15 AM
RPMCanes's Avatar
Default Noise when moving side to side
I can hear sort of a bumping noise when the car moves side to side. Is there an engine mount on the driver's side? I had all the motor mounts replaced under warranty less than a year ago so I'm thinking they still should be covered if there's a problem.
Old Jul 13, 2010 | 07:06 PM
RPMCanes's Avatar
It turns out that the bolt in the rear motor mount is stripped out and spinning freely. That is the culprit. Hence another trip to the stealership to get it fixed thankfully under warranty.
Old Jul 13, 2010 | 07:27 PM
SVTfocusO3's Avatar
Probably need the mount then if that is the case.
Old Jul 15, 2010 | 10:06 AM
RPMCanes's Avatar
They replaced the mount, and it jerked once when I drove it out. The noise is still there. Anyone have any suggestions? Please help, this is absolutely killing me. I'm losing my faith in a Volvo's ability to be repaired.
Old Jul 16, 2010 | 12:09 PM
2002v70's Avatar
Did they check the lower front tranmission mount? Suspension bushings? Sway bar end links? Could be a host of things.
Old Jul 28, 2010 | 08:42 AM
RPMCanes's Avatar
Everything in the front end is tight. That lower transmission mount is fine. My independent Volvo mechanic is going to replace the axle nuts this week, because I hear there's some updated ones that are supposed to prevent any noises? Anyone hear anything about that?
Old Jul 28, 2010 | 11:08 PM
toddro91482's Avatar
So your description says when car moves side to side. Does that mean its suspension noise? Just wandering why you are chasing engine and transmission mounts. I have done tons of upper strut plates for suspension noises such as pops clunks stuff like that. There is no play that can be detected. The way I diagnose this is with a tool called Electronic Ear. You basically put small microphones on suspected issues and dive vehicle to find the noise.
floryed
Nov 26, 2011 09:43 PM
Lukeman
May 7, 2007 07:05 PM
S80NIGHTMARE
Jan 11, 2007 12:26 AM
tupapison
Jul 1, 2006 10:15 AM
mstrdrew
Nov 3, 2005 02:30 PM
