O2 Sensor Replacement
Old Nov 17, 2006 | 01:31 AM
Volvo2001's Avatar
Default O2 Sensor Replacement
I keep get the P0422 Code and CEL and been seeing threads on many sites that say it could be the O2 sensor.
I'm going to be replacing both of my O2 Sensors.
Is there anything special I should do BEFORE and AFTER I replace them, like have ECM reprogramed, etc?
Old Nov 17, 2006 | 12:07 PM
luke8_8's Avatar
Default RE: O2 Sensor Replacement
I just installed it and disconnected the negative terminal for a little while. Runs great now. Excellent gas milage.
Old Nov 17, 2006 | 12:52 PM
Volvo2001's Avatar
Did you get any Error Codes that indicated you needed to replace them?
Old Nov 19, 2006 | 11:46 AM
Install the sensors and HAVE the codes cleared.
The Battery disconnected will not clear them.
There is codes in 2 computers. It might turn the light off but the codes are still there.
Old Nov 29, 2006 | 01:05 AM
Volvo2001's Avatar
Thanks TECH.
Will Do on having the codes cleared instead of disconnecting battery.
Old Oct 30, 2014 | 10:46 AM
sirdave4's Avatar
I'm trying to replace my downstream O2 sensor but i have no idea how to get a socket up behind the catalic converter to get it off. Any quick tips or ideas? I purchased the 7/8 socket from Auto zone but even then, it looks impossible.
Old Oct 30, 2014 | 07:04 PM
mainesail's Avatar
I'm assuming you realize that the downstream sensor has absolutely no effect on how the car operates. It's only there to monitor the operation of the convertor.
soduku007
Oct 7, 2019 04:01 PM
ruggles
Mar 3, 2010 04:19 PM
mctan
Feb 2, 2010 03:16 AM
Scanman
Jan 28, 2010 07:01 PM
sabydady
Jul 7, 2009 04:58 PM
