oil
Old Jan 30, 2014 | 11:11 AM
alanmcnair's Avatar
Default oil
what oil is best or good for volvo s60 03 turbo??
Old Jan 31, 2014 | 03:38 AM
oragex's Avatar
If the car has been running on non synthetic oil (or you don't know which oil was), switching to synthetic must be done with caution. Synthetic will start 'cleaning' the engine and will quickly clog the oil filter for the first 2-3 oil changes. I would change 2 oil filters at each 500-1000 miles (just reuse the oil or top up if removing the filter alone). Also regularly check oil level on synthetic as it may start consuming some oil.
Any "synthetic" 5W30 oil will do well, such as Castrol Syntec, Mobil 1 or Pennzoil Platinum.
Old Jan 31, 2014 | 05:55 AM
ES6T's Avatar
Not true at all.
Old Feb 1, 2014 | 03:54 AM
alanmcnair's Avatar
thanks im a female im kat just using my mans account, i havent got a clue but ur advise helps thankyou
Old Feb 1, 2014 | 04:01 AM
alanmcnair's Avatar
Red face oil
thanks for the info helps alot im kat just using my mans account im the driver, had the car a year off the rd just now bat flat or never had enough petrol in the car was sitting for a while i was ill, then it wouldnt start i never ticked it over, so before i put a bit of petrol in and bat get charged up need to get oil in thanks again kat x
Old Feb 1, 2014 | 04:04 AM
alanmcnair's Avatar
hi thanks for the info im kat using my mans account as im the driver thanks again
nuclearseal
Aug 17, 2022 01:48 PM
endneu913
Nov 21, 2010 10:53 AM
nationm
Feb 12, 2006 10:09 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
