Power Steering Fluid Check
Old Dec 22, 2008 | 03:58 PM
jafargio's Avatar
Default Power Steering Fluid Check
Hi...
how should I check Power Steering fluid? Should it be on started engine?
I have checked engine off and fluid is higher than line hot. is it ok or should I remove some?
and after some periods there is wet around fluid tank.
please some suggestions.
Thanks
Old Dec 22, 2008 | 04:40 PM
billofdurham's Avatar
Default RE: Power Steering Fluid Check
Park on level ground with the front wheels straight ahead. Switch off the engine. The level should be between the max and min marks. If it is above the max mark remove some fluid. I use a small syringe for this job.
Old Dec 22, 2008 | 08:39 PM
shadowboxer47's Avatar
Checked my fluid this morning. Noticed it was a little towards being low rather than high. Should I level it, or will such a small amount not really matter?
Old Dec 22, 2008 | 09:07 PM
I always check it with the car off. When the car is running it will read a little lower with the fluid flowing. I fill it to the middle between low and full.
Old Dec 23, 2008 | 02:10 AM
jafargio's Avatar
I have recently checked fluid and its higher then max. and I noticed wet around fluid tank. Should it be the reason that there is a lot?
Old Dec 23, 2008 | 07:18 AM
Someome must have overfilled it.
Old Dec 23, 2008 | 11:05 PM
Will that harm the car or just make a mess?
Old Dec 23, 2008 | 11:13 PM
Pretty much just make a mess.
westsacxj
Jul 13, 2017 07:50 PM
katiejoyful
Dec 12, 2007 04:49 PM
Majki
Jun 10, 2007 12:37 PM
reg
Mar 17, 2005 07:57 PM
Steamroll9
Jan 9, 2005 12:11 AM
