Power Window Glass replacement
Old 03-06-2009 | 03:19 PM
v2001s60t's Avatar
Exclamation Power Window Glass replacement
Hello Volvo owners!
I'm new to this site and figured maybe I can get some help here. I have a 2001 S60 2.4T and I just went through a dunkin donut drivethru and the window crashed down when I opened it. I took the door panel off only to find out that those little plastic guide peices that slide on the windown guide rail (not sure if this is making sense) came off the steel lifters. thery were not broke they just looked as if they "popped" off. Anyhow the window is cracked so i need a new one.
Does anyone know if I can order a window and replace it myself? Is this difficult? How is it done and what will be needed. Thank you for any advice and guidance! !
Old 03-06-2009 | 09:11 PM
Yes you can replace it your self. It is not that hard.
You will need a new window and guides. Usually the plastic breaks where the arm lock in.
mark458
09-01-2010 10:56 PM
mmlco
08-31-2009 06:31 PM
schrysco
02-27-2009 12:33 PM
wallst32
02-22-2009 02:15 PM
schrysco
02-19-2009 08:11 PM
Quick Reply: Power Window Glass replacement
