question for Tech, unless someone else knows, turning noises
So i test drove a 02 s60 t5 with 60k miles on it, it was beautiful. Only thing was when i turned the wheel it made like a noise, lik rubber on rubber, or rubber against something, deffinately not grinding, and it wasnt just when i turned the wheel the entire way, it was turning the wheel regularly, it was very odd..... and suggestions, or advice??
A larger size tires may cause rubbing... Verify that the tires are not rubbing on the inside fender well or rubbing on the mud flap when you turn the wheel. You can check this buy turning the wheel L or R and then looking inside the fender well for the approximate clearance.
buckybob
11-14-2013 01:57 PM
djalmab
11-07-2008 08:11 AM
