Removing oil pan
Old Aug 26, 2017 | 05:27 PM
Pmongii's Avatar
Smile Removing oil pan
2004 S60 124000 miles.
I ran over some rocks and punctured my oil pan. So I'm trying to remove it so I can put another one on. I removed all the bolts and I just can't get it out.
I'm able to move it freely as it's detached from the motor, just can't get it out.
Any suggestions?
Old Sep 11, 2017 | 07:15 AM
jerick1976's Avatar
You'll probably have to loosen the engine mounts, jack the engine from above using a cherry picker and lower the subframe to get it off. Sounds like things have moved around inside the pan due to the hole punch.
Old Sep 13, 2017 | 10:06 AM
Pmongii's Avatar
Any suggestions?
thank you for replying. You are right, lifted motor a little came right out and real easy to change.
BlueGiant
Oct 19, 2012 05:06 PM
AnEskimo
Mar 17, 2012 08:06 AM
philosophico
Apr 7, 2009 08:52 AM
Keith Tobberman
Nov 26, 2007 12:35 PM
