Replacing Struts, what else to replace?
at the least the spring seats, they get worn in and lower the car, youre going to need an alignment after all this aswell, unless you make really good markings and put everything back together close to the way it was. there is bearing plates in the front too, they go bad after a while, but dont skimp on these get the OEM ones because the cheaper ones I got had some play in them, but the noise I had is now gone. you might want to get new swaybar links too, theyre pretty cheap and easy to replace.
i dont know much about the rear other than there might be a spring seat back there too
IPD spring seats should be fine... check this out, it should help if youre doing it yourself
http://turbobil.com/SMF/index.php/topic,13.0.html
shwebo
01-30-2012 09:00 PM
ycartf
10-05-2010 03:18 PM
