s60 2007 shift lock problem
Old Jan 23, 2011 | 07:29 PM
sherwood112's Avatar
Default s60 2007 shift lock problem
hello i have a 2007 volvo s60, very cold today in ct, started car fine, gear selector stuck in park, i can hear the shift lock release when i depress the brake pedal, but it doesn't seem to release the gear shift lever to go into r or drive. turned car off then to position II a couple times then started again , tried this a few times then the shift lock worked and i was able to move the shifter. is this normal when it is real cold, has not done this before. note that i can hear the release when i press the brake ?? any help appreciated
Old Dec 27, 2015 | 12:49 PM
bikerider58's Avatar
The same thing happened to me this morning with my 04 S60.
Did you get an answer?
I am thinking of opening it up for a cleaning and silicone lube.
Old Sep 22, 2019 | 09:20 AM
dando's Avatar
Hello, My 2005 XC70 gets locked in Park or Drive... I currently have the solenoid disconnected (out of the car). I also had a local mechanic remove the solenoid away from the mechanism but still plugged in lying away from the gear shift but still operating electronically. This year/model does not have a manual gear shift unlock button (why would a manufacturer even install such button). I am now driving with the console removed and gear shift exposed to see what happens the next occurrence as it is intermittent and only occurs once every several weeks/months at of course the worst times. Car is unsafe and cannot be driven by wife of kids with this going on.
Any help would be great appreciated, Thank You.
dando
Sep 23, 2019 10:01 AM
newmex999
Aug 20, 2014 02:29 PM
ccove
Dec 28, 2011 08:41 PM
mach3833
Sep 26, 2010 01:42 AM
act1292
Aug 11, 2010 07:04 AM
