S60 headlight failure
Old Jul 2, 2020 | 08:13 AM
Zack Gunther's Avatar
Default S60 headlight failure
Sorry if this is a repost. Couldn’t find it if is.
09 s60 2.5t
replaced both low beam bulbs. They worked fine for 2-3weeks. Now I’m getting a bulb failure but only with the turn signal on. The bulb dims and starts flashing with the turn signal. What’s my first step to getting this fixed? Thanks in advance.
Old Jul 2, 2020 | 06:17 PM
are the headlights still working ok? its really not that uncommon for both headlights to go out relatively close to one another, particularly if you leave them on as running lights. As to the turn signals, did you replace those bulbs yet? I'd start by replacing the bulbs and while you have them out check the sockets for any signs of corrosion/looseness. Then check voltage at the socket and on the ground. could be a bad bulb, a socket issue or a bad ground. Last it could be the flasher relay or the multi-function stalk.
Mack Grade
Jan 4, 2016 08:03 PM
robertmossa
May 21, 2011 05:30 PM
family XC70
Mar 26, 2010 10:23 PM
us11186
Oct 17, 2006 12:26 AM
IKE8120
Dec 21, 2004 12:56 AM
