Are S60 headlight lenses plastic or glass?
Old Jun 5, 2012 | 01:44 PM
mhphoto's Avatar
Default Are S60 headlight lenses plastic or glass?
Are S60 headlight lenses plastic or glass? I'm used to the glass lenses on my 850. My '05 S60 is showing a little oxidation, so I'm assuming they're plastic. Just want to confirm before I restore them.
Old Jun 5, 2012 | 03:15 PM
J. A. Higgins's Avatar
My 2002 s60 is glass, might be plastic in later years.
Old Jun 6, 2012 | 01:15 AM
sonicj's Avatar
'06 is definitely plastic.
Old Jun 6, 2012 | 07:00 AM
sonicj's Avatar
sonicj's headlight refinishing tips of the day:
- Start with a 320 grit sponge type sanding block.
- The factory UV clear coat is extremely tough to remove. The light on the left had to be re-done as I hadn't completely sanded down past all of the clear.
- Keep it wet. I used a drop or two of car wash soap in a spray bottle filled with water.
- The bumper takes 10minutes to remove
- The Sylvania headlight restoration kit is well worth the $20. If you go this route, the final step needs to go down thick and fast!
- Stock up on Ibuprofen
-sj
Attached Thumbnails Are S60 headlight lenses plastic or glass?-volvo-headlamp1.jpg
Old Jun 11, 2012 | 01:44 AM
mhphoto's Avatar
Thanks for the answers everyone. Can't wait until my new HL restoration kit gets here!
Old Jun 19, 2012 | 09:12 AM
djgiovanni's Avatar
2001 - 2004 glass
2005 - 2009 plastic
piv15
May 10, 2013 02:03 PM
daver80
Oct 9, 2008 06:16 PM
98v70
Apr 26, 2007 10:16 AM
AlanS
Nov 5, 2006 06:25 PM
lotusing
Oct 26, 2006 05:04 PM
