S60 Howling/Whistling Noise
Old Jul 15, 2010 | 12:13 PM
apple4life's Avatar
Default S60 Howling/Whistling Noise
I have a '03 S60 AWD 2.5T and I'm sporadically hearing a howling noise. --It's a lot like the sound of someone blowing across the top of a bottle. The volume level of the howling varies and I've noticed it at high and low speeds. Some times I can even feel it reverberate through the gas pedal. I've tried increasing my speed to stop the sound, but that doesn't seem to work... Although, braking while it's making that noise seems to temporarily stop it.
ANY tips/advice would be great!
-Let me know if you need more from me. Thx!!
melissa
Old Jul 17, 2010 | 07:18 AM
Does it happen all the time or only under wet conditions?
Old Jul 18, 2010 | 09:48 AM
celjock's Avatar
http://forums.swedespeed.com/showthread.php?34578
Check out this website which may explain the source of the noise. I have the same car and experienced the same noise under wet and slushy conditions. Good luck.
Old Jul 20, 2010 | 02:09 PM
apple4life's Avatar
The conditions don't seem to really matter, it makes that noise when it's dry and/or wet out. It's pretty sporadic and hard to replicate...
I read on another post that it may be low PS fluid. I'm gonna check it out and see if that's my issue. Thanks for the link though!!
Old Jul 20, 2010 | 06:58 PM
The bottle might also need to be replaced as well.
Old Jul 21, 2010 | 09:28 AM
apple4life's Avatar
The bottle??... (Sorry)
melissa
Old Jul 21, 2010 | 09:45 AM
cjard's Avatar
Turbo noise? Or is it lower pitched than that?
Old Jul 21, 2010 | 12:08 PM
apple4life's Avatar
I recently had my Turbo checked out, that is good (thank GOD!... $$$$)
Old Jul 22, 2010 | 11:33 PM
Racer_S's Avatar
im trying to diagnose a similar problem with my car now (its coming from driver side front)... i thought it was a wheel bearing.. replaced that and the noise is still there.. i just had new tires put on so I dont think its that, but I didnt drive the car with any other tires before. next I might replace the half shaft because it seems to be making a small clicking noise when spinning the wheel back and forth when its jack up (drivers side) but its nothing urgent and I dont think a bad half shaft would make that noise but i wont know till i try.
also i'd like to replace the angle gear fluid, i dont hink its ever been done and the car is approaching 146k
the noise sound like woo woo woo woo.... when doing about 40 and you cant really notice it unless the windows are up
Old Jul 24, 2010 | 06:01 PM
The power steering fluid bottle. There is a plastic tube that goes from the top where the small hose attaches to the bottle. But the piece is inside the bottle. If it falls off it can make a noise that sounds like it is low on fluid all the time.
joker_r_me
Dec 28, 2011 07:37 PM
sVolvo60
Jul 21, 2010 12:56 AM
armeca
Apr 6, 2010 07:12 PM
SunshinyDay
Dec 9, 2009 10:14 AM
8T9GTA
Nov 24, 2007 09:22 PM
