S60R Front End Center Whirring Noise - HELP!!!
Old Jun 10, 2011 | 06:56 PM
VioTTR's Avatar
Default S60R Front End Center Whirring Noise - HELP!!!
Having some issues with a whirring noise within the front end of my vehicle which only occurs when accelerating and when the AWD Control Module is enabled. Thinking something with the driveshaft of some sort does anyone have any idea?
Alright so here's the characteristics of this issue.
  • Best described as a 'Whirring' Noise <--By the Mechanic
  • Only occurs when accelerating
  • Direction does not influence the sound 'Turning the wheel left and right'
  • Noise sounds as if it's coming from the front center -> front right
  • Noise is nonexistent upon deactivation of the AWD (Haldex) Control Module
  • ***Performance is not effected by the noise***
If this helps I now have two mechanics completely stumped!
Video of the sound Here!
Old Jun 10, 2011 | 09:27 PM
b5254t's Avatar
How do you know when the AWD is being activated? Are you sure you dont mean the abs? Have you checked for a cracked tone ring on the axle?
Old Jun 10, 2011 | 11:54 PM
VioTTR's Avatar
I know whether the AWD is deactivated because that's what happens when you pull the AWD Control Module Fuse When the car is in FWD Mode...the noise is no longer present. It's not the tone ring as I'm not experiencing any codes regarding ABS and/or clunking of anysort.
hayn5-0
Jun 29, 2011 07:14 PM
karl53201
Feb 28, 2009 08:07 AM
blankooie
Dec 21, 2008 02:40 PM
Sabre
Jul 8, 2008 08:28 AM
mskitty
Oct 13, 2006 08:08 PM
