power steering whirring noise
Old Dec 19, 2008 | 10:13 PM
blankooie's Avatar
Default power steering whirring noise
Sometimes if I have a little too much fun and do a hard turn while giving it some power I get a whirring noise from what I assume is somewhere in the power steering system. The noise will continue to repeat as I do turns but slowly disappears as I drive. This only happens after I'm rough with it.
Is there an air bubble in the PS system or should I look elsewhere? the fluid level is normal atm.
ALSO: Does anyone else get a bit of fluid leakage around the power steering reservoir? Like around the top and bottom halfs of the tank? I can only imagine it gets forced out by pressure somehow?
Old Dec 20, 2008 | 06:50 AM
Default RE: power steering whirring noise
Remove the cap for the reservoir and look inside by where the small hose attaches to the bottle. There is supposed to be a plastic tube that goes to the bottom of the bottle. Sometimes the plastic tube falls off and causes the problem you have.
Old Dec 21, 2008 | 02:40 PM
Delirious's Avatar
The noise could be caused the belt slipping or low fluid level. My hose was also leaking at the bottom of the tank, which eventually caused a low fluid level andnoisy pump.1stI tried to tighten the hose with a multitude of different clamps to no avail. A new hose from the stealershipis $110, sofinally I just trimmed the hose 3/4" from the end and that solved the issue.
hayn5-0
Jun 29, 2011 07:14 PM
VioTTR
Jun 10, 2011 11:54 PM
dave1786
Apr 17, 2010 10:15 PM
karl53201
Feb 28, 2009 08:07 AM
mskitty
Oct 13, 2006 08:08 PM
