Sitting in traffic and engine died
Old Mar 15, 2022 | 04:21 PM
Grey Bearded One's Avatar
Default Sitting in traffic and engine died
2002 S60 Base.
Recently had steering rack replaced. Flex pipe has a hole in it. Don't know if either have anything to do with this.
Today, sitting at a light I heard a high pitched whistle but I didn't think that it was coming from my car. Then, the engine cuts out. Restarted it without a problem but now the whistle is gone. Drove to where I was going and back again without a problem.
No warning lights on the dash.
Any thoughts.
Old Mar 16, 2022 | 08:22 AM
Dingus1's Avatar
Maybe your flex pipe is whistlin at ya
Old Mar 16, 2022 | 02:15 PM
Would that cause the engine to quit? I could see it making noise.
The flex pipe was replaced this morning so we'll see if it dies again.
Old Mar 16, 2022 | 02:17 PM
Dingus1's Avatar
I do not think it would make the engine die at all
Old Mar 17, 2022 | 07:43 AM
I was thinking, and I'm probably wrong, that the hole could be letting too much air into the exhaust which would screw with the readings for the O2 sensor.
Old Mar 17, 2022 | 09:20 AM
more commonly whistling is a symptom of a PCV system issue. If it happens again, try pulling out the dipstick to see if it stops. You can also try a "rubber glove" test to see if you have positive crank case pressure.
Old Mar 17, 2022 | 11:08 AM
I haven't done the glove test in a year. Probably time to do it again.
Old Mar 18, 2022 | 03:42 PM
Did the glove test last night. It passed.
rphud
Jan 8, 2013 01:10 PM
britcan
Oct 3, 2010 11:56 PM
jackstone
Jan 29, 2008 08:42 AM
dcorless
Dec 14, 2007 05:03 AM
PAPPYBALL
Feb 17, 2007 01:57 AM
