Strange overheating issue?
Old Feb 16, 2009 | 05:50 AM
swedes60's Avatar
Default Strange overheating issue?
After a 20 minute drive on the freeway at legal speeds I stopped for about 5-10 minutes. After that when I started the car again, it immediately started overheating. I could see the needle move to the red zone and then ENGINE HOT warning came up.
What could have caused this? I suspect I might have blown off a hose of some sort?
Old Feb 16, 2009 | 06:18 PM
Are you sure it was actually overheating?
Maybe the ECT is bad and telling the engine computer it is hot when it actually is not.
Old Feb 16, 2009 | 06:23 PM
swedes60's Avatar
I forgot to tell you guys that I noticed that when the heaters inside the car were on full blow the needle stabilized itself where it usually was(in the middle). Although if I went over 2000 rpm the needle started rising again.
So because I didnt see any loose hoses or had any leaks I assume this is an thermostat issue?
It all came so sudden though and at the very worst time. At round 4AM on the freeway + a lot of rain.
I called my mechanic and he said that some s60's have a "newer" type of thermostat that costs around 150-200 dollars. But he thought since mine is a 2001 s60 t5 it would have the "old" one for around 10-15 dollars. Is this correct? I searched google and got a couple of hits for the one that costs 15dollars so I guess that is the one I need.
Old Feb 16, 2009 | 06:25 PM
swedes60's Avatar
Thank you for your answer tech, seems we both wrote at the same time.
I dont really know if it is overheating, because when I opened up the hood it really didnt seem that warm. I touched a couple of hoses but wasnt bad at all.
Is that ECT a common problem? How much would it cost?
Old Feb 16, 2009 | 06:46 PM
Its somewhat common.
I would change the ECT and thermostat.
Check on FCPgroton.com for the price on the sensor.
Old Feb 17, 2009 | 09:02 AM
VolvoS40S60's Avatar
Thumbs up
You can also check www.IPDUSA.com for your Volvo parts. I use these guys always & they are very helpful if you need to speak with someone for a part needed. I wouldn't ask questions to diagnose a problem, but you can call or check their website for specific parts. Good luck!
Old Feb 18, 2009 | 02:09 AM
swedes60's Avatar
ECT sensor & thermostat changed... works perfect now!
Old Feb 18, 2009 | 06:50 PM
Glad all is good!
fluffernutter
Mar 12, 2014 10:43 AM
kapka42
Oct 18, 2010 04:47 PM
mc73186
Apr 29, 2010 10:36 AM
Philly240
May 25, 2009 08:52 PM
Earthdome
Oct 15, 2008 07:18 AM
