Thermostats: jiggle pin or no jiggle pin?
Old Feb 27, 2021 | 10:13 AM
Grey Bearded One's Avatar
Default Thermostats: jiggle pin or no jiggle pin?
Yeah, I'm obsessing about this thermostat. I've read in the past that my thermostat should have a jiggle pin. However, the Mahle 92 C thermostat that I ordered from FCP Euro does not have the jiggle pin.
Should I be concerned?
I'm not even sure what the jiggle pin does. Some sources says "it let's air bleed out" and others say "it's to let a trickle of cold water into the engine so the engine doesn't get shocked when the thermostat opens."
Old Mar 4, 2021 | 05:07 AM
My80chevette's Avatar
The jiggle pin is used for releasing air from the cooling system. Many of the newer manufacture thermostats use a different method of achieving the same thing without the additional point of failure a jiggle pin tends to be. Plus it's cheaper to manufacture and they still get to charge the same price 😁.
stickbuilder
2001-2013 model year V70
Aug 11, 2012 07:24 AM
Pej
Feb 16, 2012 07:21 AM
guyprich
Jan 12, 2012 06:49 PM
axelm
Dec 2, 2007 08:22 AM
skyman
Apr 9, 2006 01:25 AM
